SIZEITEM howto ?
Fawcett, David
David.Fawcett at STATE.MN.US
Thu Nov 2 09:25:34 EST 2006
Stephane,
To use this, you would add a column to your shapefile or dataset that contained an integer value for how large you would like the symbol for that feature to be drawn.
This allows you to set different symbol sizes for each feature as opposed to setting up separate classes with distinctive styles in the layer in the map file.
http://mapserver.gis.umn.edu/docs/reference/mapfile/style
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Stéphane COLZY
Sent: Thursday, November 02, 2006 8:16 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] SIZEITEM howto ?
Could someone give us a brief description on how to use the STYLE / SIZEITEM property on points data ?
Like: what are the other related properties, what kind of attributes/fields are supported ?
It would be very helpful...
stephane
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061102/9312a4b7/attachment.html
