LABEL BUFFER question
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Nov 6 12:51:59 EST 2006
Try change the LAYER type from POINT to ANNOTATION.
-Steve W
Paul Dugas wrote:
> I'm annotating some polygons using a POINT layer so I can put the
> label along with a dot. I've got a BUFFER value for the LABEL and it's
> removing those that are too close but it's not removing the
> corresponding dots. Is there a way to have them linked so the dot is
> removed when the label doesn't fit?
> Paul
> * Paul Dugas *
> / Computer Engineer / * Dugas Enterprises, LLC *
> 522 Black Canyon Park
> Canton, GA 30114
> phone: 404.932.1355
> fax: 866.751.6494
> paul at dugas.cc <mailto:paul at dugas.cc> http://DugasEnterprises.com
> <http://dugasenterprises.com/>
> / This e-mail and any attachments are confidential. If you receive this
> message in error or are not the intended recipient, you should not
> retain, distribute, disclose or use any of this information and you
> should destroy the e-mail and any attachments or copies. /
