WCS return image naming
Ben Tuttle
funkbucket at GMAIL.COM
Wed Nov 8 11:02:50 EST 2006
Hi all-
I am working on a server that will be primarily for WMS and WCS.
Whenever I make a request for an image from through WCS the resulting
image is named mapserv.tif. I am wondering if there is a way to set
the name of the file returned so it is more meaningful to the user? An
example of my mapfile is below in case it helps.
NAME DMSP-Test
STATUS ON
SIZE 864 312
EXTENT -180 -65 180 65
UNITS dd
SHAPEPATH "/mnt/anchor1/eogmaps/data/"
IMAGECOLOR 255 255 255
WEB
IMAGEPATH "/mnt/anchor1/eogmaps/www/html/tmp/"
IMAGEURL "/tmp/"
METADATA
"wms_title" "DMSP Demo Server" ##required
"wms_onlineresource"
"http://eogmaps.ngdc.noaa.gov/cgi-bin/mapserv.exe?" ##required
"wms_srs" "EPSG:4326" ##recommended
END
END
PROJECTION
"init=epsg:4326" ##required
END
OUTPUTFORMAT
NAME GEOTIFF
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE "BYTE"
EXTENSION "tif"
END
SYMBOL
NAME "BigLine"
TYPE ellipse
POINTS
1 1
END
END
LAYER
NAME "Countries"
METADATA
"wms_title" "Countries" ##required
END
STATUS on
TYPE polygon
DATA "world_adm0.shp"
CLASS
NAME "Countries"
STYLE
SYMBOL BigLine
SIZE 2
OUTLINECOLOR 255 75 0
END
END # class
PROJECTION
"init=epsg:4326"
END
END # layer
LAYER
NAME "F152003_stretched"
METADATA
"wms_title" "F152003_stretched" ##required
END
STATUS on
#PROCESSING "SCALE=AUTO"
PROCESSING "SCALE_1=0,63"
TILEINDEX "tiles/F152003_v2_stable_lights_index.shp"
TILEITEM "Location"
# DATA "F152003_stretched.tif"
TYPE raster
PROJECTION
"init=epsg:4326"
END
END
LAYER
NAME "F152003_v2_stable_lights"
METADATA
wcs_description "F152003 v2 stable lights"
wcs_name "DMSP Annual Composite"
wcs_label "F152003"
ows_srs "EPSG:4326"
ows_extent "-180 -65 180 65"
wcs_resolution "0.0083 -0.0083"
wcs_bandcount "1"
wcs_formats "GEOTIFF"
wcs_nativeformat "8-bit GeoTIF"
wcs_rangeset_name "F152003_v2_stable_lights"
wcs_rangeset_label "F152003"
wcs_rangeset_axes "bands"
wcs_bands_rangeitem "_bands"
wcs_bands_name "bands"
wcs_bands_semantic "http://www.ngdc.noaa.gov/dmsp/"
wcs_bands_refSys "European Petroleum Survey Group (EPSG)"
wcs_bands_label "F152003"
wcs_bands_values "VIS"
END
STATUS off
DUMP true
TILEITEM "Location"
TYPE raster
PROJECTION
"init=epsg:4326"
END
END
END #Mapfile
