Actual location of True Type font files for fonts in Font
Suitcases under Mac OS X 10.4.
Keith Kaneda
kaneda at JHU.EDU
Wed Nov 8 17:26:26 EST 2006
Hello List,
I recently installed the MapServer 4.10.0 cgi binaries for OS X on a
dual 2.0 GHz PowerPC G5 system running OS X 10.4.8 and started working
through the exercises from Bill Kropla's "Beginning MapServer: Open Source
GIS Development" book. When trying to work through several map examples
which use True Type fonts, I would keep getting the error message similar
to the following:
msGetLabelSize(): TrueType Font error. Requested font (arialbd) not found.
This would occur when I would try to point to the OS X installed fonts in
/Library/Fonts or ~/Library/Fonts in my font.list file, e.g.
arial /Library/Fonts/Arial
The pathname I listed above points to a file of Kind "Font Suitcase".
In the case of the Arial font, the Finder lists the size of this file as
312 KB. When you open the font in Font Book, it is possible to see which
files are included in the Font Suitcase and by choosing Preview | Show
Font Info, you can confirm that a font (e.g. Arial Regular) is indeed a
TrueType font. Font Book lists the location of the font as either
/Library/Fonts or ~/Library/Fonts. When I go to the /Library/Fonts and
~/Library/Fonts directories using the Terminal, the font files of type
"Font Suitcase" have a file size of 0! Many of the fonts in the
example Font Set file on the MapServer web site (e.g. Arial family,
Georgia family, Times family, Trebuchet-MS, Verdana family) seem to be in
Font Suitcase files under OS X 10.4.
I was finally able to complete several of these exercises by using the
folder of Vera family fonts bundled in the MapServer 4.6 tutorial so
that error wasn't caused by an erroneous pathname in the FONTSET
statement. My question is this - where do the .ttf files for True Type
fonts listed as type/kind Font Suitcase actually reside under OS X 10.4?
If someone is succssfully running MapServer under OS X 10.4 and using the
standard True Type fonts installed by OS X 10.4, I would appreciate it if
you could post or send me a copy of your font.list file.
Thanks for any info,
-Keith
Keith Kaneda INTERNET : kaneda at jhu.edu
Senior Information Technology Specialist, VOICE : (410) 516-7741
Basic and Social Sciences FAX : (410) 516-6229
Library Digital Programs, The Sheridan
Libraries
Johns Hopkins University
3400 North Charles Street
Baltimore, MD 21218
