(intermittent) poor text quality on ANNOTATION layers
Hal Mueller
hal at MOBILEGEOGRAPHICS.COM
Wed Nov 8 21:15:34 EST 2006
I have long had a nuisance-level problem with the quality of TrueType
font text, where sometimes a label will appear fuzzy, as if it is
being drawn twice, one or two pixels apart. When I upgraded to 4.10
last week the problem became much worse, so I am trying to fix it.
I have tried lots of variations in my mapfile, but I still end up
with text that causes headaches. I would appreciate any suggestions.
I suspect that I am tickling some boundary condition in the antialiasing code.
An example can be seen at
http://www.sailwx.info/shiptrack/shiplocations.phtml?lat=40&lon=-72&radius=100
If I switch to primary colors (e.g. 255 0 0), quality is much
improved. If I use a white background (BACKGROUNDCOLOR 255 255 255),
quality is perfect. It makes no difference whether I use JPEG, PNG,
or GIF output. I am using only default drivers--haven't tried things
like DRIVER "GDAL/JPEG" yet, nor have I tinkered with IMAGEMODE.
Here's a sample CLASS definition:
CLASS
LABEL
BUFFER 1
ANTIALIAS TRUE
COLOR 156 156 156
# BACKGROUNDCOLOR 255 255 255
FONT "OptimaItalic"
SIZE 3
MAXSIZE 10
MINSIZE 8
Type truetype
POSITION AUTO
END
END
I'm running 4.10 on a Redhat box. Library versions:
gdlib 2.0.33
freetype 2.1.10
gdal 1.3.1
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I guess the next thing I try is picking other colors for
text/land/sea, but before I do that I'd like to hear ideas on things
I can try with the image model or other parts of the system.
TIA,
Hal
