postgis views?
Michael Schulz
mschulz at WEBGIS.DE
Fri Nov 10 06:20:44 EST 2006
do you get an error or just a blank image? Maybe post a debug output
from the layer that uses the postgis connection (e.g. with shp2img)?
And/Or the layer section of your mapfile.
Using pg-views to display data is generally working.
Cheers, Michael
On 11/10/06, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all,
> we are not able to use in mapserver data from postgres/postgis views,
> even if the_geom column of view was add to the geometry_column table).
> Anybody had a similar problem?
> All the best.
> pc
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.5 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFFVFOc/NedwLUzIr4RAlGlAKCxgZas03i0njogMrMjoMSoGVKf6ACgrNNT
> TKMptXmeFJrlbiHVsuxCBMk=
> =8sLR
> -----END PGP SIGNATURE-----
Michael Schulz
mschulz at webgis.de
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
