problems with zoom / layers
Eduardo Zenaide
ezenaide at GMAIL.COM
Fri Nov 10 13:26:46 EST 2006
thanks a lot, Blaise! :D
about my other question, i've changed in the map file the resolution, but
when i zoom in and do some query the map extents. it not resize, but zoom
out to its max. i've tried comment some functions to see if i can identify
where it happens but not sucessfully.
any ideas?
2006/11/10, Blaise <bpicinbono at worldonline.fr>:
> Try switching MS_SINGLE to MS_MULTIPLE in the queryByPoint function around
> line 510 in the gmap75.inc.php file. This should do the trick; check the
> doc
> for more details :
> http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/mapobj
> Regards
> Blaise
> Le vendredi 10 novembre 2006 18:03, Eduardo Zenaide a écrit:
> > sorry, gmail replied only to you, i didn't see it
> > what i want is to know if its possible to see, when i use the "i" tool
> over
> > a layer, results from all visible layers.
> > example: two layers (city, country) visibles, i click over one location,
> > let's say New York, it shows population from city layer AND name from
> > country layer.
> > thanks
> > > Please Eduardo, post to the list so everybody can participate.
> > > With gmap out of the box, you can do a mutliple query with the Rosa
> > > applet "i"
> > > tool. Isn't it what you are looking for ?
> > > Regards
> > > Blaise
> > > Le vendredi 10 novembre 2006 13:40, vous avez écrit:
> > > > Blaise,
> > > > about the layers, they all have a template line and work fine, but i
> > > want
> > > > to know if i can see results from more than one layer at the same
> time.
> > > > thanks
> > > > > hi there,
> > > > > 1 : check first that the layers you want queryable have a
> "template"
> > > line
> > > > > in
> > > > > the mapfile. If not, they can't be queryable.
> > > > > 2 : might be. Make a quick string search with the original extent
> in
> > > all
> > > > > the
> > > > > files and you'll see.
> > > > > Regards
> > > > > Blaise
> > > > > Le jeudi 9 novembre 2006 20:54, Eduardo Zenaide a écrit:
> > > > > > hi all,
> > > > > > there's a way to display results from various layers, for
> example,
> > > > > > i
> > > > > have
> > > > > > three layers (city, country, province). when i do the query -
> i'm
> > > > > mounting
> > > > > > my interface under gmap with ms4w - it results only the last
> layer.
> > > i
> > > > > would
> > > > > > like to display results from all layers.
> > > > > > other question: i have locked the screen on the map file as
> > > 760x500px.
> > > > > but,
> > > > > > when i zoom in and use the query tool, the map extents to the
> > > original
> > > > > > size. there's other place i should change the resolution?
> > > > > > thanks in advance :)
Eduardo Zenaide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061110/b92b4735/attachment.html
