ODBC and WKT
Frank Warmerdam
warmerdam at POBOX.COM
Wed Nov 15 09:47:04 EST 2006
Jeppe Lund Andersen wrote:
> Hello
> Iam running on a windows 2003 server and mapserver 4.8.1 and php 4.4.2
> Iam using a ODBC connection ( "ODBC:test/test at test_dns,v_aktiveflader" )
.... big wkt string ...
> When I use "$Layer->queryByAttributes($ID_navn, $ID_value,
> $ResultType);" to get the specifik shape
> it returns 0
> if I change the WKT streng to
> POLYGON((501982.449393967 6268525.27980791, 501972.653330944
> 6268522.51037162, 501956.796572362 6268519.5209801))
> It works fine.
> So is there a limit to how long the WKT string can be ?
> or a work around so I can load long WKT strings
Jeppe,
I believe older versions of GDAL/OGR had problem with long text attributes
via ODBC. What version of GDAL/OGR are you using? Can you test the same
ODBC connection using the ogrinfo from FWTools 1.0.9?
http://fwtools.maptools.org/
If the problem persists I would suggest submitting a bug report. It would
be very helpful if you could reproduce the problem with a more portable
database format, such as MS Access so you could submit a database with the
bug report. I don't run SQL Server and can't easily test stuff related to
it.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
