Problems with mapserver and oblique projections
Trond Michelsen
trondmm-mapserver at CRUSADERS.NO
Wed Nov 15 10:24:59 EST 2006
Hi.
I'm having some problems getting mapserver 4.4.1 to draw maps in an
oblique projection.
Here's an example:
http://wms.met.no/cgi-bin/mapserv?map=../vhosts/mercator/conf/google.map&LAYERS=kart,cdc,base.LATLON&TRANSPARENT=false&BGCOLOR=0x99B3CC&EXCEPTIONS=application/vnd.ogc.se_inimage&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&BBOX=-180,-90,180,90&WIDTH=800&HEIGHT=400&SRS=EPSG:44065
( http://tinyurl.com/ykem3c )
(red coastlines are drawn by mapserver, the grey land, the bluish
coastlines and the gridlines are drawn by an internal WMS-server.)
As you can see, mapserver omits most of the shapes close to the North
Pole, and there are some wrapping issues at the south pole.
the proj-definition looks like this:
+proj=ob_tran +o_proj=eqc +lon_0=0 +o_lat_p=25 +a=57.29577953604224884 +b=57.29577953604224884 +no_defs <>
(the bizarre minor and major axis sizes are used to get
pseudo-decimaldegrees as units. I should probably use some scaling
parameter instead, but I was unable to find something that corresponds
to the -m command line parameter)
and my map is configured like this in the mapfile:
LAYER
name "cdc"
data "cntry00"
status on
type polygon
PROJECTION
"+proj=latlong"
"+a=6371000"
"+b=6371000"
END
CLASS
STYLE
outlinecolor 255 0 0
END
END
END
If the tilting is more severe, even more countries are left out of the
plot:
http://wms.met.no/cgi-bin/mapserv?map=../vhosts/mercator/conf/google.map&LAYERS=kart,cdc,base.LATLON&TRANSPARENT=false&BGCOLOR=0x99B3CC&EXCEPTIONS=application/vnd.ogc.se_inimage&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&BBOX=-180,-90,180,90&WIDTH=800&HEIGHT=400&SRS=EPSG:44090
With no tilt at all, you basically get regular latlong coordinates,
and now all countries are being displayed:
http://wms.met.no/cgi-bin/mapserv?map=../vhosts/mercator/conf/google.map&LAYERS=kart,cdc,base.LATLON&TRANSPARENT=false&BGCOLOR=0x99B3CC&EXCEPTIONS=application/vnd.ogc.se_inimage&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&BBOX=-180,-90,180,90&WIDTH=800&HEIGHT=400&SRS=EPSG:44000
Does anyone know what I'm doing wrong? Is there something I can do to
get mapserver to plot all countries in this projection? (Preferrably
without the wrapping issues).
Trond Michelsen
