Shapefile classification by attribute
D. Eric Keefauver
eric.keefauver at MTU.EDU
Wed Nov 15 11:48:54 EST 2006
Hello,
I have been an ArcIMS user for quite sometime and have been "playing" with
Mapserver (the ITASCA demo)in rendering simple shapefiles. My question is
this: I have a county shapefile (83 counties) that has a few attributes
in the file e.g., -- Shape -Name - Acres_2002- Acres_2003- Cost_2002 -
Cost_2003- etc.
I would like to be able to display an attribute on user selection. For
instance, if the user selects Acres_2002 the map would display the
attribute field Acres_2002 based on some sort of classification with the
end result being a chloropleth rendering of the attribute field
Acres_2002. Can this be done with straight Mapserver functionality? I am
using MS4W v1.4.0.
I thank you in advance,
Eric
Eric Keefauver
Research Scientist
Michigan Tech Research Institute (MTRI)
3520 Green Court, Suite 300
Ann Arbor, MI 48105-1579
Phone: 734-302-4724
Fax: 734-302-4991
eric.keefauver at mtu.edu
http://www.mtri.org
