Logical Expressions
D. Eric Keefauver
eric.keefauver at MTU.EDU
Thu Nov 16 12:03:05 EST 2006
New to MS. My question is this: I am wanting to use a logical expression
within a layer in my mapfile. The below expression will render the county
with the exact acreage of '438282.297'. How would I set it to display all
acreages in the field that are < 500,000 ? Syntax? I am running MS4W v
1.4.0. Also, could this value (500,000) be set by a user through, say,
via a form?
Thanks much
Eric
LAYER
NAME Michigan_county_eqip
TYPE POLYGON
STATUS OFF
DATA Michigan_county_eqip
CLASSITEM 'ACRES'
CLASS
NAME "ACREAGE" #This is read into the legend
EXPRESSION '438282.297'
OUTLINECOLOR 0 0 0
COLOR 173 216 230
TEMPLATE "county_eqip.html"
END
CLASS # every other county in the state
NAME "COUNTIES"
OUTLINECOLOR 211 211 211
COLOR 119 136 153
END
HEADER "county_eqip_header.html"
FOOTER "county_eqip_footer.html"
TOLERANCE 3
DUMP TRUE # allow GML export
END
Eric Keefauver
Research Scientist
Michigan Tech Research Institute (MTRI)
3520 Green Court, Suite 300
Ann Arbor, MI 48105-1579
Phone: 734-302-4724
Fax: 734-302-4991
eric.keefauver at mtu.edu
http://www.mtri.org
