raster projector
Frank Warmerdam
warmerdam at POBOX.COM
Thu Nov 16 15:04:58 EST 2006
John Smith wrote:
> guys,
> trying to put a geotiff in- works but not right. here's what's happening:
> i download the geotiff from national atlas. when i give no proj info
> under LAYER it shows up but not where it should (nwis). so i copy MAP
> proj to LAYER proj hoping for some on-the-fly magic- again it shows up
> but nwis.
> well i go over to proj_list
> <http://www.remotesensing.org/geotiff/proj_list/> and look up the epsg
> (EPSG?) code (9820) from metadata but it throws the
> "msProcessProjection(): Projection library error. no options found in
> 'init' file" error. then i try all epsg codes given by gdalinfo ;) but
> same error. although when i try the MAP epsg code (4326) it shows up but
> nwis.
> so what's wrong here? think proj.exe geod.exe cs2cs.exe libgeotiff
> listgeo'd help? now i don't think wld is needed because it's included
> with the geotiff but i've tried with wld and no luck. i just hope i
> don't have to rectify in arcmap. btw IMAGETYPE=png24 in case that matters.
John,
I don't believe there is an EPSG code corresponding to this coordinate
system:
PROJCS["TIFF 6.0, GeoTIFF Revision 1.0",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",45],
PARAMETER["longitude_of_center",-100],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
But the corresponding PROJECTION block to put in the LAYER definition
is:
PROJECTION
"+proj=laea +lat_0=45 +lon_0=-100 +x_0=0 +y_0=0 +datum=WGS84 +units=m"
END
At one time you could also put:
PROJECTION
"AUTO"
END
and MapServer would read it from the geotiff file, but I'm not sure if this
still works.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
