Ruby mapscript oddness
The Cunctator
cunctator at GMAIL.COM
Fri Nov 17 14:09:48 EST 2006
I'm happy to give settings/sample files etc but maybe someone has some idea
what my problem is -- I'm guessing it has to do with the installation.
The following script:
#!/usr/bin/env ruby
require "mapscript"
include Mapscript
map=MapObj.new("test.map")
image = map.draw
image.save('test.png')
fails:
in `draw': msEvalExpresssion: Expression parser error. Failed to parse
expression;msyyparse(): Expression parser error. syntax
error;msEvalExpression: Expression parser error. Failed to parse
etc.
whereas the php script
<?php
if(!extension_loaded("MapScript")) {
dl('php_mapscript.'.PHP_SHLIB_SUFFIX);
$map = ms_newMapObj("test.map");
$image = $map->draw();
$image->saveImage('test.png');
works fine.
map.drawLegend
and
map.drawScalebar
work fine.
Anyone have thoughts or what information would people need to diagnose?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061117/afd65ab5/attachment.html
