Identifying a size-scaled symbol point
Luca Manganelli
luca76 at GMAIL.COM
Sat Nov 18 03:00:41 EST 2006
I've defined a symbol (a square) that I use with my point shapefile.
The problem is this: the symbol size varies with the map scale.
So, how can I identify the point if the symbol is greater, AND, within
the scale-based size of symbol ?
"Work only as many hours as you can be productive and only as many hours as
you can sustain." - Kent Beck, in "Extreme Programming Explained"
http://www.trapanator.com/blog
