Raster tile indexing in PostGIS
Thy, Kristian
Kristian.Thy at ATKINSGLOBAL.COM
Wed Nov 22 07:24:32 EST 2006
Quoting the Raster Data Access HOWTO
<http://mapserver.gis.umn.edu/docs/howto/raster_data>:
"The list of files forming a layer can be stored in a shapefile with
polygons
representing the footprint of each file, and the name of the files.
This is
called a TILEINDEX ..."
The tileindex, we're told, is defined in the map file like this:
LAYER
NAME "hpool"
STATUS ON
TILEINDEX "hp2.shp"
TILEITEM "Location"
TYPE RASTER
END
My question is then: Is it possible (and if yes, desirable) to read the
tileindex from a PostGIS data source instead of a shapefile - i.e. use
gdatindex to create the tileindex, then convert the index .shp using
shp2pgsql and stuff it into PostGIS. My understanding is that using
plain ole shapefiles you miss out on the gist indexing and thus suffer
a performance loss.
best regards,
Kristian Thy
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
