WMS Help please
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Nov 27 21:55:17 EST 2006
percy,
Thanks, but that does not seem to work for me. On 4.6.2, which has WMS
server but does not list WMS client, or 4.10 which has support for both.
"wms_styles" does not seem to get picked up and added to the url but if
I add the styles= to the CONNECTION url it fails with the 403 error, but
if I copy and paster the url from the debug log into the browser I get
the expected image.
I think this is another bug.
Can anyone else test this and let me know if they can reproduce it. I am
wondering if jpl is blocking the Mapserver client?
Here is a test mapfile:
MAP
NAME "wms-jpl"
STATUS ON
EXTENT -180.0 -90.0 180.0 90.0
SIZE 400 250
IMAGECOLOR 200 200 200
IMAGETYPE png
UNITS DD
#DEBUG ON
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
LAYER
NAME "global_landsat"
TYPE RASTER
DEBUG TRUE
STATUS DEFAULT
MINSCALE 20000
CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?STYLES="
# following does not pick up the wms_styles
# CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "modis,global_mosaic"
"wms_styles" "" #### this seems to be ignored!!!
"wms_server_version" "1.1.1"
"wms_format" "image/png"
END
END
END
-Steve
percy wrote:
> Steve, here's mine that works in 4.6
> LAYER
> NAME global_landsat
> TYPE RASTER
> STATUS on
> CONNECTIONTYPE WMS
> MINSCALE 20000
> METADATA
> "wms_format" "image/jpeg"
> "wms_styles" ""
> END
> END
> Stephen Woodbridge wrote:
>> Any WMS experts online, I still haven't figured this one out.
>> Is it just me or has the list been pretty quite lately?
>> -Steve
>>> Hi all,
>>> Just downloaded and built mapserver 4.10 and I'm have a strange
>>> problem with a WMS Layer.
>>> The apache error log says:
>>> libpng warning: Incomplete compressed datastream in iCCP chunk
>>> libpng warning: Profile size field missing from iCCP chunk
>>> [Sun Nov 26 18:29:29 2006].383652 HTTP: Starting to prepare HTTP
>>> requests.
>>> [Sun Nov 26 18:29:29 2006].383796 HTTP request: id=0,
>>> http://wms.jpl.nasa.gov/wms.cgi?STYLES=&LAYERS=global%5Fmosaic&REQUEST=GetMap&SERVICE=WMS&FORMAT=image%2Fpng&HEIGHT=200&VERSION=1.1.1&SRS=EPSG:4326&WIDTH=300&BBOX=35%2E2716150733968%2C33%2E7132053155979%2C35%2E7478323266032%2C34%2E0306834844021&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
>>> [Sun Nov 26 18:29:29 2006].383989 HTTP: Before download loop
>>> [Sun Nov 26 18:29:29 2006].774669 msHTTPWriteFct(id=0, 595 bytes)
>>> [Sun Nov 26 18:29:29 2006].774730 msHTTPWriteFct(id=0, 73 bytes)
>>> [Sun Nov 26 18:29:29 2006].774748 msHTTPWriteFct(id=0, 9 bytes)
>>> [Sun Nov 26 18:29:29 2006].774765 msHTTPWriteFct(id=0, 115 bytes)
>>> [Sun Nov 26 18:29:29 2006].774780 msHTTPWriteFct(id=0, 166 bytes)
>>> [Sun Nov 26 18:29:29 2006].774800 msHTTPWriteFct(id=0, 1 bytes)
>>> [Sun Nov 26 18:29:29 2006].874799 HTTP: After download loop
>>> [Sun Nov 26 18:29:29 2006].874819 msHTTPExecuteRequests() timing
>>> summary per layer (connect_time + time_to_first_packet +
>>> download_time = total_time in seconds)
>>> [Sun Nov 26 18:29:29 2006].874886 HTTP: HTTP GET request failed with
>>> status 403 () for
>>> [Sun Nov 26 18:29:29 2006].874920 Layer 0: 0.125 + 0.266 + 0.225 =
>>> 0.615s
>>> [Sun Nov 26 18:29:29 2006].875030 msDrawMap(): Layer 0 (JPL-WMS), 0.000s
>>> If I load the URL directly into the browser is returns fine, but from
>>> mapserver I get
>>> HTTP: HTTP GET request failed with status 403 () ... from above.
>>> The layer definition looks like:
>>> LAYER
>>> NAME "JPL-WMS"
>>> TYPE RASTER
>>> DEBUG TRUE
>>> STATUS DEFAULT
>>> CONNECTIONTYPE WMS
>>> METADATA
>>> "wms_name" "global_mosaic"
>>> END
>>> END
>>> MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>>> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
>>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=TIFF INPUT=EPPL7
>>> INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE DEBUG=MSDEBUG
>>> Anyone have a clue on what I'm doing wrong, or is this a bug?
>>> Thanks,
>>> -Steve W
