projection confusion...
Mark Dieterich
mdieterich at GMAIL.COM
Thu Nov 30 23:50:08 EST 2006
Evening everyone,
I'm hoping some of you can help dig me out of my utter confusion ;)
I've been humming along, working with mapserver for a while and never
really giving projections much thought. Then came tiling... It
requires a constant mapping between pixel values and the geographic
space. Enter confusion...
I'm working with tiger data, national atlas data, and some home grown
data (based off the tiger data, so it will have the same projection as
the tiger data). So far, all I've managed to do is draw blank maps, so
I know I either have projection mis-matches or extents which are foobar.
The first issue I have is, how do you determine what projection the data
is already in? I've seen about three different answers to the question
re: national atlas data; none of them seem to make any difference for
me. I've tried playing with ogrinfo to query the underlying shapefiles
and haven't found anything remotely helpful.
I decided to follow the all mighty google and have my output projection
be in a mercator projection, so I have this in my mapfile:
PROJECTION
"proj=merc"
"lat_ts=0.0"
"lon_0=-90.0"
"x_0=0.0"
"y_0=0.0"
"ellps=GRS80"
"no_defs"
END
which I think is correct. Now I figure I just need to get my various
data layers defined with an appropriate projection and life might get
better.
As for my second issue, how do I convert from decimal/degree extents to
meters? I tried running something like this:
proj +proj=merc +lat_ts=0.0 +lon_0=-90.0 +x_0=0.0 +y_0=0.0 +ellps=GRS80
+no_defs
and then entering in my lat/long values. It returned some really nice,
big, numbers, but I haven't a clue whether they were right. Again,
blank map.
I clearly have a lot to learn about map projections, but I've spent
many, many, many hours searching around the net trying to answer these
questions and it's only led to more frustration. Can anyone out there
offer up some help?
Thanks!
Mark
