MySql OGR connection failure
Karl Suiter
karl.suiter at GMAIL.COM
Sat Oct 28 21:11:20 EDT 2006
Hi All,
OK, I'm stumped. I'm running Mapserver cgi on Fedora Core 5 with no
problems. However, I am trying to map point data stored in a MySql
database.
I've configured and compiled the cvs release of gdal/ogr sucessfully
for both MySql and ODBC connectivity.
gdal/ogr
./configure \
--with-geotiff=/usr/local/lib \
--with-libtiff=/usr/lib \
--with-xerces \
--with-mysql \
--with-odbc=yes \
--with-geos \
--without-libtool \
--with-png \
--with-jpeg \
--with-gif
ogrinfo --formats
Supported Formats:
-> "ESRI Shapefile" (read/write)
-> "MapInfo File" (read/write)
-> "UK .NTF" (readonly)
-> "SDTS" (readonly)
-> "TIGER" (read/write)
-> "S57" (read/write)
-> "DGN" (read/write)
-> "VRT" (readonly)
-> "AVCBin" (readonly)
-> "REC" (readonly)
-> "Memory" (read/write)
-> "CSV" (read/write)
-> "GML" (read/write)
-> "KML" (read/write)
-> "Interlis 1" (read/write)
-> "Interlis 2" (read/write)
-> "ODBC" (read/write)
-> "PGeo" (readonly)
-> "OGDI" (readonly)
-> "MySQL" (read/write)
Mapserver 4.8.4 has also been compiled with OGR support ...
mapserver
./configure \
--with-gif \
--with-png \
--with-jpg \
--with-pdf \
--with-wbmp \
--with-svg \
--with-ogr=/usr/local/bin/gdal-config \
--with-gdal=/usr/local/bin/gdal-config \
--with-proj=/usr/include \
--with-freetype=/usr/bin/freetype-config \
--with-gd=/usr/local/include \
--with-curl-config=/usr/bin/curl-config \
--with-wfsclient \
--with-wmsclient \
--with-threads \
--with-wcs \
--with-wfs \
--with-mysql=/usr/bin/mysql_config \
--with-odbc \
--with-httpd=/usr/sbin/httpd \
--with-libiconv=/usr \
--with-geos= \
--enable-debug
./mapserv -v
MapServer version 4.8.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=EPPL7 INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
I'm able to connect to the database using ogrinfo with no problem
(I can also connect using ODBC).
ogrinfo MySQL:xxxx01,user=xxxx,password=xxxx01,host=localhost,
port=3306,tables=division_dist
INFO: Open of `MySQL:xxxx01,user=xxxx,password=xxxx01,host=localhost,
port=3306,tables=division_dist'
using driver `MySQL' successful.
1: division_dist (None)
Now comes the part that is not working. I can create both a .ovf connection
file and also embed the connection string in my .map file like so ...
LAYER
NAME MAP_POINTS
STATUS OFF TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
"<OGRVRTDataSource>
<OGRVRTLayer name='ADMIN_REGIONS'>
<SrcDataSource>MYSQL:xxxx01,user=xxxx,password=xxxx01,host=localhost,
port=3306,tables=division_dist</SrcDataSource>
<SrcSQL>SELECT latitude_deg, longitude_deg from division_dist where
pest_id = %pestid% AND (latitude_deg < > 0 AND longitude_deg
< > 0)</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding='PointFromColumns' x='latitude_deg'
y='longitude_deg'/>
</OGRVRTLayer>
</OGRVRTDataSource>"
DATA "MAP_POINTS"
STATUS default
CLASS
STYLE
SYMBOL 'circle'
SIZE 5
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
END
END
However, calling this layer in a browser gives the following error
msDrawMap(): Image handling error. Failed to draw layer named
'MAP_POINTS'.
msOGRFileOpen(): OGR error. Open failed for OGR connection
` MySQL:xxxx01,user=xxxx,password=xxxx01,host=localhost,
tables=division_dist '.
Failed to open datasource `MySQL:xxxx01,user=xxxx,password=xxxx01,
host=localhost,tables=division_dist'.
The same error occurs when I use the ODBC driver. FYI - when I run the .ovf
file usign ogrinfo, I can connect and return the data from the MySql database.
The only thing I can determine is that mapserver is not picking up the
LD_LIBRARY_PATH is not being set. I've added LD_LIBRARY_PATH to httpd.conf and
/etc/ld.so.conf and restarted the server. Still no go. I even attempted to
create a wrapper around the mapserv cgi (exporting LD_LIBRARY_PATH and then
calling mapserv) but this did not work correctly.
Lastly, this doesn't appear to be a permissions issue. When I use the MySql
root login and password, the conection still fails.
If anyone has solved this problem and be willing to share the secret?
Cheers,
Karl
