[Fwd: Re: mapserv stdout png problem]
Tamas Szekeres
szekerest at GMAIL.COM
Mon Oct 30 17:48:49 EST 2006
I recall that the original proposal was:
http://www.nabble.com/Proposing-to-support-for-creating-maps-with-mapserv.exe-using-the-command-line-p4976104.html
As far as I remember against this proposal suppressing the header was
the desired approach, however suppressing the header at all places
like the OWS requests seemed to be a PITA.
Tamas
2006/10/30, Hubert Asamer <hubert.asamer at univie.ac.at>:
> ---------- Továbított levél ----------
> From: Frank Warmerdam <warmerdam at pobox.com>
> To: Hubert Asamer <hubert.asamer at univie.ac.at>
> Date: Thu, 26 Oct 2006 15:55:24 -0400
> Subject: Re: mapserv stdout png problem
> Hubert Asamer wrote:
> > Frank,
> > one more question regarding the FW_Tools mapserv.exe:
> > When i make a query like this: mapserv "Query_string=map=.....&mode=map"
> > i get a png with following header: Content-type: image/png
> > Then i must remove the first two lines of the png file and i can view my
> > result-everthing ok!
> > Do you know how to configure my query to avoid these two header lines?
> Hubert,
> There was some talk recently about adding a commandline switch to mapserv
> to supress this, but looking in the code it looks like nothing was done.
> So, no, there is nothing that can be done.
> My msautotest test suite has special python code to strip off these mime
> types, and the WxS mapscript wrappers include a mechanism to strip off
> the mime type. But I can't think of anything you can do when invoking mapserv
> at the commandline.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> __________ NOD32 1.1831 (20061024) Information __________
> Diese E-Mail wurde vom NOD32 antivirus system geprüft
> http://www.nod32.com
