Map with road signs
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Mon Apr 16 14:18:33 EDT 2007
Is a road sign a combination of a base sign and then an identifier (e.g.
road number)? If so then
you can build those using a combination of classes (to define the base
sign) and a label. This is the
standard way of handling road signs.
The other idea, that is, SYMBOL [signcolumn] will be possible in 5.0
(see RFC 19) but might become
problematic from a performance perspective.
Steve
>>> On 4/13/2007 at 1:37 PM, in message
<2F86ED212F3E164EB9FBB2E68C67858E0499574C at SINFRA0-EXC003.MTQ.MIN.INTRA>,
Léveillé, James <James.Leveille at MTQ.GOUV.QC.CA> wrote:
> Hi,
> I need to produce a map that shows road signs.
> I have over 1200 types of road signs, and a total of 1.2 M road
signs.
> I have the position (POINT) and the type of every road sign.
> Every sign needs to show up on my map using a particular image
depending on
> it's type.
> Since I don't want to create 1200 CLASS in my LAYER, is there
another
> solution (like using the name of the image stored in the database for
every
> sign) ?
> ______________________________________________________
> JAMES LÉVEILLÉ
> Service des systèmes de Mission
> Direction des technologies de l'information
> Ministère des Transports du Québec
> 5833, boul. Pierre-Bertrand, 2ième étage
> Québec (Québec) G2K 1K7
> Téléphone: (418) 380-2005 poste 227
> Télécopieur: (418) 644-6653
> james.leveille at mtq.gouv.qc.ca <mailto:james.leveille at mtq.gouv.qc.ca>
