MS 4.10.1 php_mapscript build problem on FreeBSD 6.2
Ben Madin
ben at REMOTEINFORMATION.COM.AU
Wed Apr 18 04:50:51 EDT 2007
Thank you Steve,
I have mod_fastcgi for apache, this was installed through the FreeBSD
ports system, and all very happily. but I didn't end up with a
libfcgi anywhere I can find (I have mod_fastcgi.so in my /usr/local/
libexec/apache22 directory)
I notice in the configure I actually had this :
configure: checking whether FastCGI support should be enabled...
checking for FCGI_Accept in -lfcgi... no
configure: checking HTTPD server (Apache) version...
using user-supplied httpd (/usr/local/sbin/httpd)
/usr/local/sbin/httpd version is Apache/2.2.4 (2002004).
Compiling with fast MS_NINT
checking compiler warnings... basic
so maybe I never had fastcgi last time around. Do I need to get a
different fastcgi from somewhere else, or did something maybe not go
quite right?
cheers
Ben
> From: Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>
> Date: 18 April 2007 9:26:39 AM
> Subject: Re: MS 4.10.1 php_mapscript build problem on FreeBSD 6.2
> -lfcgi is the fastcgi library. You can see if you have it loaded
> with something like:
> locate libfcgi
> probably should be at /usr/local/lib/libfcgi*
> if it is there, or somewhere on your system, check to make sure its
> path is in /etc/ld.so.conf and run as root ldconfig and try again.
> -Steve W
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
ben at remoteinformation.com.au
Out here, it pays to know...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070418/1d1cc6eb/attachment.html
