Virtual Tables
Fawcett, David
David.Fawcett at STATE.MN.US
Wed Apr 18 14:03:34 EDT 2007
How is it failing?
Are you getting an error message?
Are you specifically calling the layer by name in the URL or post
request, or have you tried setting STATUS to DEFAULT?
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Kevin Flanders
Sent: Wednesday, April 18, 2007 12:41 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Virtual Tables
I would like to map a virtual table, and I am told I can do it
without declaring an ODBC...using the following mapfile layer
definition:
LAYER
NAME "Fire Data"
GROUP "Fire Data"
STATUS on
TYPE point
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer
name='firegis'>
<SrcLayer>mapsonline.csv</SrcLayer>
<GeometryField
encoding='PointFromColumns' x='XCOORD' y='YCOORD'/>
<GeometryType>wkbPoint</GeometryType>
</OGRVRTLayer>
</OGRVRTDataSource>"
TEMPLATE "ttt"
TOLERANCE 4
CLASS
NAME "Fire Data"
SYMBOL "circle"
OUTLINECOLOR 80 80 80
COLOR 219 0 0
SIZE 12
END
END
But this fails. Do I need an ODBC....or is it true I can access
a text file directly in this manner. The data is being placed with all
my other shapefiles (ie. in the same folder).
Also, can the .csv file just as easily be a .txt file....and can
the entries have quotations around them?
Kevin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070418/2d637582/attachment.html
