AW: [UMN_MAPSERVER-USERS] No drawing of certain polygon rings
stroed in Oracle Spatial
"Schönhammer, Herbert"
Schoenhammer.Herbert at REGENSBURG.DE
Thu Apr 19 11:56:59 EDT 2007
Hi Fernando,
I'm in hurry, but a short report of my results:
1.
Yes, the validate function returns true !
2.
After using SDO_GEOM.SDO_ARC_DENSIFY geometries with SDO_ELEM_INFO (1;1003;1 ...) are built. These geometries are drawn by mapserver. (Of Course; now these geometries are simple polygons, connected by stright lines.)
3.
I really don't understand the 'arc_tolerance= xx' parameter of this function. Chosing them very big, smaller, .... smallest, ... I NEVER could create a simpler object, which is an approximation of the original geometry. (A polygon with 5 edges is NO approximation of a circle). So I have to play with this command. (I don't understand the dependencies of the tolerance-value in the diminfo-array of the layer at this point of time )
regards
Herbert
>-----Ursprüngliche Nachricht-----
>Von: Fernando Simon [mailto:fsimon at univali.br]
>Gesendet: Mittwoch, 18. April 2007 13:35
>An: Schönhammer, Herbert
>Betreff: Re: AW: AW: [UMN_MAPSERVER-USERS] No drawing of
>certain polygon rings stroed in Oracle Spatial
>Hi Hebert,
> Sorry for the delay to send some news. In the last week I was
>thinking about your problem, the validate function return true, right?
>Did you already try to use, and validate, the objects in
>another Oracle
>versions (9i, 10g)?
> Another thing is try to test the function
>SDO_GEOM.SDO_ARC_DENSIFY to
>convert this objects to a more simple object. Can you try this to test?
> Sorry again for the delay.
>Fernando Simon
>Schönhammer, Herbert wrote:
>> Hi Fernando,
>> have you got some time for searching a solution for "my" problem ?
>> Actual i have to build a WMS using Mapserver to support
>another project in my work. So i Don't have a lot of time anymore.
>> I will be glad of any kind of solution or tipp or workaraound.
>> Main problem: the application used for generating and
>editing the data in the oracle database (Autodesk Topobase 3)
>is storing circles as described in my mails. About 20
>employees are working every day with this database. So i'm not
>able to make a copy of the database and make some workarounds,
>because i have to deliver the actual data !
>> Thanks very much,
>> regards
>> Herbert
>>> Gesendet: Montag, 2. April 2007 14:05
>>> Betreff: Re: AW: [UMN_MAPSERVER-USERS] No drawing of certain
>>> Hi Schönhamer,
>>> Sorry for the delay to reply some news from Brazil.
>>> I didn't have much time to look about this issue, the
>Master was a
>>> little complicated last week. I already started to investigate the
>>> problem, the Oracle standard and the driver for Mapserver.
>>> I don't know if this week (With the easter holiday) I can
>>> work more,
>>> but I will try to develop something.
>>> Before it, can you send to me all the info about your
>system? And
>>> the objects that not work. Another importnt thing is the
>UMN Mapserver
>>> version and the Mapfile that you used.
>>> Best regards from Brazil.
>>> Fernando Simon
>>>> Hi,
>>>> have you got some time for looking at the problem ??
>>>> Best regards
>>>> Herbert Schönhammer
>>>>> Von: UMN MapServer Users List
>>>>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Im Auftrag von
>Fernando Simon
>>>>> Gesendet: Montag, 19. März 2007 04:33
>>>>> An: MAPSERVER-USERS at LISTS.UMN.EDU
>>>>> Betreff: Re: [UMN_MAPSERVER-USERS] No drawing of certain
>>>>> Hi,
>>>>> The problem that you report it's strange, I need to
>>>>> investigate more
>>>>> to try find the solution. This approach to draw the circle I
>>>>> never used.
>>>>> Maybe (very possible) that the problem with the
>>> SDO_INTERPRETATION
>>>>> and SDO_GTYPE that you relate is the core of the problem.
>>>>> You can try to simplify your arc's as lines, Oracle 9i
>contains a
>>>>> function that transform arc's to lines, I don't remember the
>>>>> name now (I
>>>>> don't have the docs here now). You can try this way to solve the
>>>>> problem, you need to test the interoperability of these converted
>>>>> polygons with Topoase.
>>>>> Now I can't test (I'm starting my Master), I just can
>>> test, change
>>>>> the code and report a solution after the day 26.
>>>>> Best regards.
>>>>> Fernando Simon
>>>>> UMN Mapserver and Oracle Spatial developer
>>>>>> Hi,
>>>>>> I have some troubles drawing of certain geometries, stored
>>> in Oracle
>>>>>> Spatial 9i.
>>>>>> In general, I'm able to say, that polygon rings are drawn without
>>>>>> problems (Connected by line strings or compound line strings
>>>>> connected
>>>>>> by circular arcs AND line strings). But there are some
>types, which
>>>>>> are not drawn by mapserver. There is no warning or error
>>> reported by
>>>>>> mapserver ! These certain geometries only are not present in
>>>>> the drawn
>>>>>> png-file (or what ever). The geometries in the neighbourhood
>>>>> are drawn !
>>>>>> My Environment
>>>>>> - Oracle 9i with Spatial Option on a Windows 2003 Server
>>>>>> - MapServer 4.8.4 (Mapserver 4.10.1 does the same !) on a
>>> SuSE SLES 9
>>>>>> compiled with an Oracle 10g - Client
>>>>>> - MapServer used as WMS-Server
>>>>>> In detail the geometry, whis is NOT drawn by mapserver
>>>>>> Our application (Autodesk Topoase 3) is not storing a circle as a
>>>>>> circle in Oracle Spatial. The circle is splitted into two arcs,
>>>>>> connected to each other at the end-/start-points of the arcs. The
>>>>>> drawn picture should be the picture of a circle.
>>>>>> The stored geometry has the properties:
>>>>>> GTYPE 2003 (= 2-dim POLYGON)
>>>>>> In Detail:
>>>>>> (2003; 82032; ; (1; 1003; 2; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ;
>>>>>> ; ; ; ; ; ); (4505542,97176542; 5430753,10554764;
>4505541,58808944;
>>>>>> 5430750,58265205; 4505544,16794032; 5430749,30831663;
>>>>>> 4505545,28931113; 5430751,74858283; 4505542,97176542;
>>>>>> 5430753,10554764; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ;
>>>>>> The geometry validates
>>> (SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT), the
>>>>>> result is TRUE.
>>>>>> The same geometry stored as LINE or CURVE IS drawn !!
>>>>>> GTYPE 2002 (= 2-dim LINE or CURVE)
>>>>>> (2002; 82032; ; (1; 2; 2; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ;
>>>>>> ; ; ; ; ); (4505542,97176542; 5430753,10554764; 4505541,58808944;
>>>>>> 5430750,58265206; 4505544,16794032; 5430749,30831663;
>>>>>> Note
>>>>>> Changing the mapserver Layer TYPE from POLYGON to LINE (or
>>>>> vice versa)
>>>>>> does not have any effect !!!
>>>>>> In detail a "circle", which IS drawn by mapserver
>>>>>> (2002; 82032; ; (1; 4; 1; 1; 2; 2; ; ; ; ; ; ; ; ; ; ; ; ; ;
>>>>>> ; ; ; ; ; ); (4506079,8746; 5430398,0938; 4506070,0144;
>>> 5430388,2336;
>>>>>> 4506079,8746; 5430378,3734; 4506089,7348; 5430388,2336;
>>> 4506079,8746;
>>>>>> 5430398,0938; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ;
>>>>>> The geometry also validates
>>>>>> the result is TRUE.
>>>>>> BUT:
>>>>>> Please look at the first triplet of SDO_ELEM_INFO.
>>>>>> Looking in Oracle Documentation, the combination of
>>>>> SDO_ETYPE=4 with a
>>>>>> SDO_INTERPRETATION=1 is NOT allowed. SDO_INTERPRETATION MUST
>>>>> be bigger
>>>>>> than 1.
>>>>>> (Is there a bug in the doc ??????)
>>>>>> My problem
>>>>>> Creating new circles, the application stores them as GTYPE
>>>>> 2003, which
>>>>>> is not drawn !
>>>>>> Does anybody know, what's the matter?
>>>>>> Is there anybody, who has some tipps for me ?
>>>>>> With kind regards
>>>>>> *Schönhammer Herbert*
