Use of different epsg code
antonio
volpicelli at OATO.INAF.IT
Thu Apr 19 17:41:56 EDT 2007
Hi ,
I am new of mapserver. I am using mapserver for an astronomic
application and I would like to use Mollweide projection ( epsg:54009).
I am able to draw the graticule ( the ellipse ) using this layer
inside mapfile.
First of all in the top of mapfile I defined these :
MAP
NAME ASTRO
STATUS ON
#EXTENT -180 -90 180 90 EXTENT -18000000 -9000000 18000000 9000000
UNITS dd
#IMAGECOLOR 0 123 123
TRANSPARENT ON
SHAPEPATH "G:/GalexData/TestPoint"
CONFIG "PROJ_LIB" "E:/ms4w/proj/nad/"
. PROJECTION
"init=epsg:54009"
END
The layer definition for the graticule:
LAYER
NAME "Grid"
METADATA
"DESCRIPTION" "Grid"
END
TYPE LINE
STATUS OFF
CLASS
NAME "Graticule"
COLOR 123 123 123
END
PROJECTION
"init=epsg:4326"
#"init=epsg:54009"
END
GRID
MAXARCS 1
MAXINTERVAL 15
END
END # Layer
So this work but I don't really understand why I have to define the
EXTENT as -18000000 -9000000 18000000 9000000 and not as -180 -90 180 90
and in the layer "Grid" definition I cannot define the init=epsg:54009
but init=epsg:4326 . If I use 54009 , mapserver goes in stall , it gets
98% of CPU and don't end never.
If now I want draw one polygon shape on this map and I use this layer :
LAYER
NAME "TestPoint"
TYPE POLYGON
STATUS ON
DATA TestPoint
PROJECTION
"init=epsg:4326"
END
LABELITEM 'tilename'
DUMP true
CLASS
NAME "TestPoint"
STYLE
SIZE 2
OUTLINECOLOR 123 123 123
COLOR 0 0 255
END
LABEL
MINFEATURESIZE 200
END
END
METADATA
GML_INCLUDE_ITEMS "tilename,survey,ra,dec,nuvexptime,fuvexptime"
WMS_SERVER_VERSION "1.1.1"
WMS_FORMAT "image/png"
WMS_TITLE "Galex AIS Survey"
WMS_ABSTRACT "SDSS DR3 imaging level 0"
WMS_SRS "EPSG:4326"
WMS_NAME "TestPoint"
#WMS_FORCE_SEPARATE_REQUEST "0" END
END
and here too , I have to use epsg:4326 and not 54009.
There are someone that could help me about this and If I want to change
the projection from Mollweide to Aitoff , is it possible and supported
by mapserver.
Thanks
Antonio
