MS4W: Queries on classified rasters
Marco Cerruti
cerruti.marco at GMAIL.COM
Fri Apr 20 09:35:11 EDT 2007
Frank,
thanks for your answer, actually I'm moving this "my-first-MapServer" to a
public host, in order to test it and then make it accessible to a (some)
possible end-user(s). Query on classified rasters was the last thing to fix,
so, as it can't be fixed now, I hope to put everything online in few days,
with contents of mapfile and templates accessible to visitors.
Besides this, tell me what else should I do to let you reproduce the same
problem.
... and thanks again!
M
2007/4/20, Frank Warmerdam <warmerdam at pobox.com>:
> Marco Cerruti wrote:
> > Hi all,
> > I'm a new user of Mapserver. I'm working with MS4W (version 2.2.3) via
> > CGI and I'm having troubles with queries on classified rasters. Queries
> > on non-classified rasters work fine, while in cases of classified ones
> > (already tried several formats: img, bil, tif, png) I get the following
> > error:
> > msDrawShape(): General error message. Unknown layer type.
> > If I comment CLASS definitions the same query shows me correct results
> > (one or more pixels queried, according to the set tolerance, but of
> > course no information on [class] value).
> > I post an extract of my mapfile, with the definition of the raster layer
> > and one of its classes. Maybe I'm doing something wrong with class
> > template (and layer header/footer ...).
> > Hoping to receive a little help ... and sorry for my English!
> Marco,
> I think this is a bug in mapserver. That I did not touch all the
> parts of the code I should have when implementing raster query support.
> Could you boil this down to a minimum test to demonstrate the problem
> and submit a bug report? If I can easily reproduce the problem with
> your test data, I'll try and fix it fairly promptly.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070420/a32752fe/attachment.html
