MS4W: Queries on classified rasters
Frank Warmerdam
warmerdam at POBOX.COM
Fri Apr 20 10:00:07 EDT 2007
Marco Cerruti wrote:
> Besides this, tell me what else should I do to let you reproduce the
> same problem.
Marco,
I am looking for a bug report with:
o A minimal map file that can be used to reproduce the problem. Strip out
all other layers, fontlists, etc not required to reproduce the problem.
o If the raster file is large, cut out a small chunk and submit this small
dataset with the bug report in stead of a large file.
o The bug report should have the exact url triggering the problem, assuming
that the problem with was mapserv.exe, not a mapscript script.
o Make clear how I will know the errors is occuring (presumably the error
message from msDrawShape()).
The objective is to give me something I can unzip, and then run mapserv
at the commandline with to reproduce the error with at most a minute or
two of fiddling to adjust things to my local environment.
Most bugs languish on the vine because reproducing the original problem is
too hard (or even just *seems* like it might be too hard).
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
