symbols - inprecise rendering
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Apr 24 10:23:36 EDT 2007
I wonder if this is due to a rounding bug introduced in 4.6 (I think). I
can't see how
GDAL would affect things. Any chance you could try 4.10 as a test with
your mapfile?
Steve
>>> "R. Müller" <r.mueller at UNICOMP-BERLIN.DE> 04/24/07 3:38 AM >>>
i've got a question concerning rendering symbols in mapserver. I'm
working with mapserver 4.6 mostly on linux-based maschines and noticed
that under certain circumstances the rendering of point symbols is quit
inexactly.
in the following test-case i wanted to draw gray-filled circles with a
black border. in this case i didn't used the newer style-syntax but the
result is quit the same. in the rendered image the two cirlces (inner
circle and border are not located in the same origin, one circle is
shifted for some pixels)
symbol-definition :
SYMBOL
NAME 'kreis'
TYPE ELLIPSE
FILLED TRUE
POINTS 1 1 END
END
inside the layer definition :
CLASS
SYMBOL 'kreis'
EXPRESSION "gray"
COLOR 0 0 0
SIZE 50
OVERLAYSYMBOL 'kreis'
OVERLAYCOLOR 200 200 200
OVERLAYSIZE 35
OVERLAYMAXSIZE 35
MAXSIZE 50
END
the data comes from a postgis-database backend, but it doesn't matter. i
worked out the following standalone test-case (complete map-file) and
the behaviour is the same :
MAP
NAME 'testy'
EXTENT 0 0 800 600
SIZE 501 521
IMAGETYPE PNG
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
LAYER
NAME 'kreis'
STATUS DEFAULT
TYPE POINT
FEATURE
POINTS 450 150 120 111 450 301 END
#POINTS 350 350 END
END
CLASS
STYLE
SYMBOL 'circle'
SIZE 101
COLOR 0 0 0
END
STYLE
SYMBOL 'circle'
SIZE 94
COLOR 121 121 121
END
TEXT 'K0025'
END
END
LAYER
NAME 'kreis1'
STATUS DEFAULT
TRANSPARENCY 50
TYPE POINT
FEATURE
POINTS 100 450 750 320 131 310 END
#POINTS 350 350 END
END
CLASS
STYLE
SYMBOL 'circle'
SIZE 51
COLOR 0 0 0
END
STYLE
SYMBOL 'circle'
SIZE 35
COLOR 211 121 121
END
TEXT 'K0025'
END
END
END
i discovered some correlation to the version of used GDAL-library :
in one case i used Version 1.3.1 and its rendered correctly (see 3rd
pic), in another case i used 1.2.6 and renders incorrectly (see 2nd
pic). Can someone confirm this behaviour ?
thanks a lot in advance.
regards
ronald
attachments :
1. first example with incorrect rendering
2. standalone mapfile with incorrect rendering (GDAl 1.2.6)
2. standalone mapfile with correct rendering (GDAl 1.3.1)
