symbols - inprecise rendering
John Cole
john.cole at UAI.COM
Tue Apr 24 10:53:38 EDT 2007
Ronald,
There was an issue with a math library in 4.6-4.8. If you try that in 4.4
or 4.10, that issue isn't there. If the bug tracker is up, you should be
able to find more information on it.
The issue was a problem with the round function, if I remember correctly
and could cause the very problem your seeing. My examples were with squares
on squares.
John
"R. Müller" wrote:
> Hi,
> i've got a question concerning rendering symbols in mapserver. I'm
> working with mapserver 4.6 mostly on linux-based maschines and noticed
> that under certain circumstances the rendering of point symbols is quit
> inexactly.
> in the following test-case i wanted to draw gray-filled circles with a
> black border. in this case i didn't used the newer style-syntax but the
> result is quit the same. in the rendered image the two cirlces (inner
> circle and border are not located in the same origin, one circle is
> shifted for some pixels)
View this message in context: http://www.nabble.com/symbols---inprecise-rendering-tf3637152.html#a10162624
Sent from the Mapserver - User mailing list archive at Nabble.com.
