configure crt1.o error on PPC64 RHEL
Ara T Howard
ara.t.howard at NOAA.GOV
Fri Feb 2 09:11:50 EST 2007
On Fri, 2 Feb 2007, Doug B wrote:
> No other advice or ideas on what's misconfigured?
http://www.google.com/search?hl=en&q=crt1.o%3A+No+such+file%3A+No+such+file+or+directory&btnG=Google+Search
basically you're operating system is incomplete with respect to
development/compilation.
does this even work for you:
harp:~ > echo "main(){}" > a.c && gcc a.c && a.out && echo success
success
i assume not. once you've got a working compiler tool-chain you should have
no problem. perhaps you've got some sort of desktop install vs. a development
version of rhe?
regards.
-a
we can deny everything, except that we have the possibility of being better.
simply reflect on that.
- the dalai lama
