configure crt1.o error on PPC64 RHEL
Doug B
ummmmm22 at GMAIL.COM
Fri Feb 2 10:15:01 EST 2007
You're right. Exact same error. Guess I need to ask elsewhere since
I've now installed the rpms that contain gcc as well as the library in
question. Thanks.
On 2/2/07, ara.t.howard at noaa.gov <ara.t.howard at noaa.gov> wrote:
> On Fri, 2 Feb 2007, Doug B wrote:
> > No other advice or ideas on what's misconfigured?
> http://www.google.com/search?hl=en&q=crt1.o%3A+No+such+file%3A+No+such+file+or+directory&btnG=Google+Search
> basically you're operating system is incomplete with respect to
> development/compilation.
> does this even work for you:
> harp:~ > echo "main(){}" > a.c && gcc a.c && a.out && echo success
> success
> i assume not. once you've got a working compiler tool-chain you should have
> no problem. perhaps you've got some sort of desktop install vs. a development
> version of rhe?
> regards.
> -a
> we can deny everything, except that we have the possibility of being better.
> simply reflect on that.
> - the dalai lama
