Re-projected rasters do not show when queryfile is used
Richard Greenwood
richard.greenwood at GMAIL.COM
Fri Feb 2 09:18:39 EST 2007
It sounds like an existing bug:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=2017
Rich
On 2/2/07, Külli Tiits <kylli.tiits at gmail.com> wrote:
> Hi,
> I am working on a project where I use MapServer in CGI-mode with dBox.
> So far everything has worked out well, but now I have a problem, to what
> I can not find a solution.
> I have some raster data that is in another coordinate system, than the
> rest of data. So I have defined the projections for these layers and the
> map in general. And the re-projected rasters are displayed on the map as
> they should. But the re-projected rasters just dissappear when a query
> is made and to URL the queryfile part is added.
> Here are 2 simplified reqests:
> https://xxx/mapserv?mode=map&map=/xxx/xxx.map&mapext=3347092+6967198+3349163+6969669&mapsize=430+513&layers=XXX
> https://xxx/mapserv?mode=map&map=/xxx/xxx.map&mapext=3347092+6967198+3349163+6969669&mapsize=430+513&layers=XXX&queryfile=/xxx/XXX.qy
> The first displays the rasters as it should. In the second re-projected
> rasters are not visible. As you can see the only difference is the last
> part with queryfile.. The not-projected rasters show up fine and the
> query results highlighting also works as it should...
> Should I somehow define projection also for the querymap or what should
> I do to make the re-projected rasters visible also with quryfile?
> The version of MapServer is 4.8. If some additional details could be
> important, I would happily provide them.
> And as this is my first letter to the list, I would also like to say a
> big thank you, to everybody who have been developing MapServer and dBox!
> Kylli
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
