Problem with connecting to MySQL with OVF-file
Gaston Izaguirre
gizagui at FI.UBA.AR
Wed Feb 7 20:26:28 EST 2007
Chris,
try this, if you have not done it, in the geometry field of your .ovf file,
replace "x" and "y" with the name of the columns of the waarnemingen table
that represents the xcoord and ycoord respectively, e.g.:
<GeometryField encoding="PointFromColumns" x="longitude" y="latitude"/>
Regards,
Gaston.
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, February 07, 2007 4:12 PM
Subject: [UMN_MAPSERVER-USERS] Problem with connecting to MySQL with
OVF-file
> Hello,
> I'm running Mapserver and pMapper on a Linux-Debian system and I have
> installed MySQL, added a database called dop and a table called
> waarnemingen.
> I created a waarnemingen.ovf which looks like this:
> <OGRVRTDataSource>
> <OGRVRTLayer name="Waarnemingen">
> <SrcDataSource>MYSQL:dop,user=root,password=testje,host=84.244.182.83,port=3
> 306,tables=waarnemingen</SrcDataSource>
> <SrcSQL>SELECT * FROM waarnemingen</SrcSQL>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="x" y="y"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> When I run ogrinfo /var/www/data/maps/waarnemingen.ovf I get the following
> message:
> ERROR 4: Update access not supported for VRT datasources.
> ERROR 1: Failed to open datasource
> `MYSQL:dop,user=root,password=trashcan,host=84.244.182.83,port=3306,tables=w
> aarnemingen'.
> FAILURE:
> Unable to open datasource `/var/www/data/maps/waarnemingen.ovf' with the
> following drivers.
> -> ESRI Shapefile
> -> UK .NTF
> -> SDTS
> -> TIGER
> -> S57
> -> MapInfo File
> -> DGN
> -> VRT
> -> AVCBin
> -> REC
> -> Memory
> -> CSV
> -> GML
> -> ODBC
> -> PostgreSQL
> The host is the IP-number of the server where MySQL is running. Using
> localhost or 127.0.0.1 results in the same errors.
> Can somebody please help to connect to MySQL database. What could be
> wrong?
> Thanks.
> Chris Beaart
