scale dependent getfeatureinfo
Steven M. Ottens
steven.ottens at GEODAN.NL
Tue Feb 13 10:04:31 EST 2007
On Feb 13, 2007, at 3:25 PM, Stephen Woodbridge wrote:
> Steven M. Ottens wrote:
>> Hi all,
>> I've got a group layer with 4 scale dependent layers, with
>> aggregated elevation information: 5m resolution, 25m, 100m and
>> 500m. When I do a getFeatureInfo I get 4 results: for each of the
>> for layers a result. Being aggregated data they are all different.
>> This is slightly confusing for the user so I was wondering how to
>> solve this.
>> In my opinion the most logical process would be hat getFeatureInfo
>> honors the MINSCALE and MAXSCALE parameters. As such you only get
>> the feature info of the scalelevel currently on screen.
>> Alternatively I'd like to have only one answer, the most detailed
>> layer in this case. But I'm not sure how to disable the other
>> layers for getFeatureInfo.
>> My mapfile (without the classes since there are quite a few)
>> Regards,
>> Steven
> Steven,
> If you always get all 4 results, then only put the Query
> information in the most detailed layer and you will then always get
> just that one. IE: remove it from the other layers.
Steve,
I'm slightly at a loss here. What is the query information exactly? I
cannot remove the CLASSITEM from the other layers since they are raw
grids which need to be classified. If I remove TEMPLATE and the gml_*
items from a layer mapserver complains that layers are not queryable.
Thanks for the help,
Steven
