legend scale dependency issues
percy
percyd at PDX.EDU
Wed Feb 14 18:39:27 EST 2007
I've stripped the code down to the bare minimum. The errant behavior
persists!
Geologic faults turn on in the map (and show up in the DIV resulting
from a map->draw()) at a scale of 500000. If I then zoom in sort of
slowly, drawing a zoom rectangle just slightly smaller than the screen
each time, they'll show up the legend at around 250000. The legend gets
redrawn on every zoom.
If I use our pre-defined zoom levels, the faults don't show up at
250000, but they do show up at 100000. It sometimes seems like the
legend is a step behind.
Same behavior if I use a normal legend instead of legend template.
Just for fun (!) I tried turning on legend items (naming the classes)
for all of the other layers to see how they behaved. I had legend items
coming and going at just weird times. This was what led me to think that
it might be known bug in MapServer version 4.8.0-rc2
Below is the stripped down code, it get's called by a little AJAX-y
javascript function that stuffs the results into the innerhtml on a
popup tab. Hmmmmmmm, I wonder if the AJAX-y stuff is interfering
somehow... :-)
<?php // legend.php
// set error reporting
ini_set("display_errors", 1);
ini_set("display_startup_errors", 1);
error_reporting (E_ALL);
header("Content-type: text/html charset=utf-8");
if (isSet ($_REQUEST['extent']) &&
isSet ($_REQUEST['mapfile']) &&
isset($_REQUEST['layers'])
$extent = $_REQUEST['extent'];
$mymap = './map/' . $_REQUEST['mapfile'];
$layers=$_REQUEST['layers'];
} else {
print "<p>Invalid query string: ".$_SERVER['QUERY_STRING']."</p>";
exit;
//first set the exyent, this should take care of the scale dependencies
$map = ms_newMapObj($mymap);
if ($extent['x1'] && $extent['y1'] &&
$extent['x2'] && $extent['y2']) {
// set the extent
$map->setExtent($extent['x1'], $extent['y1'], $extent['x2'],
$extent['y2']);
//now handle turning the layers on or off
if (count($layers)>0) {
for ($i=0; $i<$map->numlayers; ++$i) {
$oLayer=$map->getLayer($i);
if (in_array($oLayer->name,$layers)) {
$oLayer->set("status",MS_ON);
} else {
$oLayer->set("status",MS_OFF);
$my_html=$map->processLegendTemplate(null);
echo $my_html;
Daniel Morissette wrote:
> The code that you included in your last email seems to be missing the
> stuff that handles the zoom. i.e. a comment suggests that you create a
> $extent_obj for this, which is either initialized from the values in the
> $extent[] array, or from the $map->extents which have just been set from
> the contents of the $extent[] array, so in both case you get more or
> less the same result minus the width/height ratio adjustment that
> MapServer does automatically on $map->setExtent()... and there is
> nothing to adjust the extents to reflect the last zoom operation and
> pass that to $map->setExtents().
> What does the $extent[] array contain when this code starts being
> executed? Is it the extents before or after applying the zoom?
> Daniel
> percy wrote:
>> Thanks Daniel, but I've been testing this pretty hard as you can see
>> from the code snippet below (testing parts are commented out). The
>> layers are getting turned on and off correctly in the section right
>> before the call to processlegendtemplate...
>> // set the extent
>> $extent['y2']);
>> // set up extent object for use in zoom (!?!?)
>> $extent_obj = ms_newRectObj();
>> $extent_obj->setExtent($extent['x1'], $extent['y1'],
>> $extent['x2'], $extent['y2']);
>> } else {
>> $extent_obj->setExtent ($map->extent->minx, $map->extent->miny,
>> $map->extent->maxx, $map->extent->maxy);
>> //echo "I see more than 0 layers\n";
>> // echo "got layer number".$i;
>> // echo "turning on layer ".$oLayer->name;
>> // echo $oLayer->status;
>> } else {
>> // echo "turning OFF layer ".$oLayer->name;
>> //echo $_SERVER['QUERY_STRING'];
>> echo $my_html;
>>> percy wrote:
>>>> When you zoom in on the map, the scale dependencies all work great
>>>> for the map, but the legend is always out of whack. I am using
>>>> php/mapscript to generate a processlegendtemplate() request. For
>>>> debugging this issue, I have also tried just a straight drawlegend()
>>>> request and I get similarly odd behavior. The geologic faults, which
>>>> are set to show up at a scale of 1:500,000 don't show up in the
>>>> legend until zoomed in to around 1:100,000. (though sometimes if I
>>>> zoom in small increments, they'll show up sooner...)
>>> The problem could be related to the order in which you make calls in
>>> your PHP script. The legend object uses the last calculated scale in
>>> its tests to decide which layer/classes to include in the legend, so
>>> if you call processlegendtemplate() before the extents and scale have
>>> been updated to reflect the last zoom operation then you could get
>>> this kind of behavior.
>>> I just did a quick check in the code and $map->setExtent() does
>>> update the scale value, so if you call that with the right extents
>>> before processing the legend then you should be fine.
>>> Daniel
David Percy
Geospatial Data Manager
Geology Department
Portland State University
http://gisgeek.pdx.edu
503-725-3373
