legend scale dependency issues
percy
percyd at PDX.EDU
Wed Feb 14 19:56:13 EST 2007
never mind! I have determined that I am doing something wrong on my end :-)
now to figure out what...
thanks again!
percy
percy wrote:
> I've stripped the code down to the bare minimum. The errant behavior
> persists!
> Geologic faults turn on in the map (and show up in the DIV resulting
> from a map->draw()) at a scale of 500000. If I then zoom in sort of
> slowly, drawing a zoom rectangle just slightly smaller than the screen
> each time, they'll show up the legend at around 250000. The legend gets
> redrawn on every zoom.
> If I use our pre-defined zoom levels, the faults don't show up at
> 250000, but they do show up at 100000. It sometimes seems like the
> legend is a step behind.
> Same behavior if I use a normal legend instead of legend template.
> Just for fun (!) I tried turning on legend items (naming the classes)
> for all of the other layers to see how they behaved. I had legend items
> coming and going at just weird times. This was what led me to think that
> it might be known bug in MapServer version 4.8.0-rc2
> Below is the stripped down code, it get's called by a little AJAX-y
> javascript function that stuffs the results into the innerhtml on a
> popup tab. Hmmmmmmm, I wonder if the AJAX-y stuff is interfering
> somehow... :-)
> <?php // legend.php
> // set error reporting
> ini_set("display_errors", 1);
> ini_set("display_startup_errors", 1);
> error_reporting (E_ALL);
> header("Content-type: text/html charset=utf-8");
> if (isSet ($_REQUEST['extent']) &&
> isSet ($_REQUEST['mapfile']) &&
> isset($_REQUEST['layers'])
> $extent = $_REQUEST['extent'];
> $mymap = './map/' . $_REQUEST['mapfile'];
> $layers=$_REQUEST['layers'];
> } else {
> print "<p>Invalid query string: ".$_SERVER['QUERY_STRING']."</p>";
> exit;
> //first set the exyent, this should take care of the scale dependencies
> $map = ms_newMapObj($mymap);
> if ($extent['x1'] && $extent['y1'] &&
> $extent['x2'] && $extent['y2']) {
> // set the extent
> $map->setExtent($extent['x1'], $extent['y1'], $extent['x2'],
> $extent['y2']);
> //now handle turning the layers on or off
> if (count($layers)>0) {
> for ($i=0; $i<$map->numlayers; ++$i) {
> $oLayer=$map->getLayer($i);
> if (in_array($oLayer->name,$layers)) {
> $oLayer->set("status",MS_ON);
> } else {
> $oLayer->set("status",MS_OFF);
> $my_html=$map->processLegendTemplate(null);
> echo $my_html;
> Daniel Morissette wrote:
>> The code that you included in your last email seems to be missing the
>> stuff that handles the zoom. i.e. a comment suggests that you create a
>> $extent_obj for this, which is either initialized from the values in
>> the $extent[] array, or from the $map->extents which have just been
>> set from the contents of the $extent[] array, so in both case you get
>> more or less the same result minus the width/height ratio adjustment
>> that MapServer does automatically on $map->setExtent()... and there is
>> nothing to adjust the extents to reflect the last zoom operation and
>> pass that to $map->setExtents().
>> What does the $extent[] array contain when this code starts being
>> executed? Is it the extents before or after applying the zoom?
>> Daniel
>> percy wrote:
>>> Thanks Daniel, but I've been testing this pretty hard as you can see
>>> from the code snippet below (testing parts are commented out). The
>>> layers are getting turned on and off correctly in the section right
>>> before the call to processlegendtemplate...
>>> // set the extent
>>> $extent['y2']);
>>> // set up extent object for use in zoom (!?!?)
>>> $extent_obj = ms_newRectObj();
>>> $extent_obj->setExtent($extent['x1'], $extent['y1'],
>>> $extent['x2'], $extent['y2']);
>>> } else {
>>> $extent_obj->setExtent ($map->extent->minx, $map->extent->miny,
>>> $map->extent->maxx, $map->extent->maxy);
>>> //echo "I see more than 0 layers\n";
>>> // echo "got layer number".$i;
>>> // echo "turning on layer ".$oLayer->name;
>>> // echo $oLayer->status;
>>> } else {
>>> // echo "turning OFF layer ".$oLayer->name;
>>> //echo $_SERVER['QUERY_STRING'];
>>> echo $my_html;
>>>> percy wrote:
>>>>> When you zoom in on the map, the scale dependencies all work great
>>>>> for the map, but the legend is always out of whack. I am using
>>>>> php/mapscript to generate a processlegendtemplate() request. For
>>>>> debugging this issue, I have also tried just a straight
>>>>> drawlegend() request and I get similarly odd behavior. The geologic
>>>>> faults, which are set to show up at a scale of 1:500,000 don't show
>>>>> up in the legend until zoomed in to around 1:100,000. (though
>>>>> sometimes if I zoom in small increments, they'll show up sooner...)
>>>> The problem could be related to the order in which you make calls in
>>>> your PHP script. The legend object uses the last calculated scale in
>>>> its tests to decide which layer/classes to include in the legend, so
>>>> if you call processlegendtemplate() before the extents and scale
>>>> have been updated to reflect the last zoom operation then you could
>>>> get this kind of behavior.
>>>> I just did a quick check in the code and $map->setExtent() does
>>>> update the scale value, so if you call that with the right extents
>>>> before processing the legend then you should be fine.
>>>> Daniel
David Percy
Geospatial Data Manager
Geology Department
Portland State University
http://gisgeek.pdx.edu
503-725-3373
