mapserver with postgis
Fawcett, David
David.Fawcett at STATE.MN.US
Thu Feb 15 16:46:20 EST 2007
Agustina,
Multipolygon is not a valid layer type in MapServer. Take a look at the mapfile reference document. http://mapserver.gis.umn.edu/docs/reference/mapfile/layer
In the LAYER section, look at TYPE. I am guessing that you might want to try POLYGON.
TYPE [point|line|polygon|circle|annotation|raster|query]
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Agustina Buccella
Sent: Thursday, February 15, 2007 3:04 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] mapserver with postgis
I have installed Mapserver and Postgis in Fedora Core 4.
My .map file has the following lines:
LAYER
CONNECTIONTYPE postgis
NAME "test"
CONNECTION "user=xxx password=xxx dbname=XX host=localhost port=5432"
DATA "the_geom from argentina"
TYPE MULTIPOLYGON
END
END
But when I try to use mapserver the web server (apache) gives me the following error:
getSymbol():Symbol definition error. (MULTIPOLYGON)
The .map file is called by using the following link in the web browser:
http://localhost/cgi-bin/mapserv?map=/data/test.map&mode=map
I have tried with other source data (sql table) and other symbols like MULTILINESTRING, etc. but I always receive the same error.
What am I doing wrong?
Thanks!
Agustina
Preguntá. Respondé. Descubrí.
Todo lo que querías saber, y lo que ni imaginabas,
está en Yahoo! Respuestas (Beta).
Probalo ya! <http://ar.answers.yahoo.com>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070215/235cf6d1/attachment.html
