Limiting the area of a mapfile that is displayed
Gregor Mosheh
gregor at HOSTGIS.COM
Sat Feb 17 13:55:46 EST 2007
>> I've got a mapfile that displays the whole of a shapefile. Is there
>> anything I can do to dynamically limit the area of the mapfile that
>> mapserver actually displays? ie so that the user can click on a
>> point, and it then zooms in and centres on that point.
That's the entire mechanism of zooming. Check the documentation
(specifically, the ) for parameters for the mapserv binary, I believe
you're interested in "mapext"
http://mapserver.gis.umn.edu/docs/reference/templatereference/templatereference
Though, if you're interested in doing maps but don't want to monkey around
with nuts and bots like this, consider using a framework like Map-Fu,
OpenLayers, Community Mapbuilder, etc.
