php/mapscript shared object
Agustina Buccella
agustina_buccella at YAHOO.COM.AR
Mon Feb 19 11:03:58 EST 2007
yes of course!!! I restart apache several times...
As I am working, I note that in the /usr/local/lib/ the libgdal.so.1 is a symbolic link:
lrwxrwxrwx 1 root root 17 feb 12 12:56 /usr/local/lib/libgdal.so.1 -> libgdal.so.1.11.0
so, I deleted this link and I copied the original (I think) libgdal.so.1 file from the gdal directory (in my case /usr/local/gdal-1.4.0/.libs/) and now I have another error:
Warning: Module 'MapScript' already loaded in Unknown on line 0
but I can see a Mapscritp table in the phpinfo page with the following data:
MapScript MapServer Version MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE PHP MapScript Version ($Revision: 1.260 $ $Date: 2006/09/06 16:42:36 $)
Thanks again!!
Agustina
Daniel Morissette <dmorissette at mapgears.com> escribió: Agustina Buccella wrote:
> My apache configuration file has the line
> SetEnv LD_LIBRARY_PATH $LD_LIBRARY_PATH:/usr/lib:/usr/local/lib:
> and in the /etc/ld.so.conf is this path too (an I run ldconfid process).
> Doing that, the mapserv script (with sgi) works well, the problem now is
> with php, but I do not know what I have to change or add....
Did you restart Apache after updating ld.so.conf and rerunning ldconfig?
Daniel
Daniel Morissette
http://www.mapgears.com/
Preguntá. Respondé. Descubrí.
Todo lo que querías saber, y lo que ni imaginabas,
está en Yahoo! Respuestas (Beta).
Probalo ya!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070219/25acb904/attachment.html
