php/mapscript shared object
Daniel Morissette
dmorissette at MAPGEARS.COM
Mon Feb 19 10:47:55 EST 2007
Agustina Buccella wrote:
> My apache configuration file has the line
> SetEnv LD_LIBRARY_PATH $LD_LIBRARY_PATH:/usr/lib:/usr/local/lib:
> and in the /etc/ld.so.conf is this path too (an I run ldconfid process).
> Doing that, the mapserv script (with sgi) works well, the problem now is
> with php, but I do not know what I have to change or add....
Did you restart Apache after updating ld.so.conf and rerunning ldconfig?
Daniel
Daniel Morissette
http://www.mapgears.com/
