WMS/WFS and (yearly) time-dependent data
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Feb 22 07:43:31 EST 2007
If your are serving layers as wms you could do soemthing like this :
- define a tileindex layer example:
LAYER
NAME "mylayer"
STATUS ON
# TYPE POLYGON
TYPE RASTER
METADATA
"DESCRIPTION" "mylayer"
"wms_title" "mylayer"
"wms_timeitem" "time"
"wms_timeextent" "1970/2006"
"WMS_SRS" "epsg:4326"
END
SIZEUNITS PIXELS
TILEINDEX "tile_file"
TILEITEM "location"
- have a tile index that has at least 2 field (localtion for the
files, and a time field) :
location time
mypath/myfile 2005
- doing a request of Getmap : something like
GetMap&Version=1.1.1&LAYERS=mylayer&Time=2005
Not sure if that fits your model.
Best Regards
Bart van den Eijnden (OSGIS) wrote:
> I think you should be looking at tile-indexing for the TIME dimension. A
> field in the dbf of the tile-index will probably state which shapefile
> Mapserver needs to open for that specific year (and that specific theme).
> I believe the WCS howto has some information on how to do this, but I have
> no experience with this whatsoever:
> http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Stefan Schwarzer <stefan.schwarzer at GRID.UNEP.CH>
> Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
> Onderwerp: [UMN_MAPSERVER-USERS] WMS/WFS and (yearly) time-dependent data
> Datum: 21/02/07 09:44
>> Hi,
>> i read in a document ( http://mapserver.gis.umn.edu/docs/howto/
>> wms_time_support/view ) that there is a WMS/WFS-parameter one can
>> specify for time dependent data. I am dealing mostly with statistical
>> data sets, which are covering a period of 1970 to 2006. So it should
>> be something like TIME=2004 to query a specific year.
>> For each variable and year there is a five-classes breakup.
>> It is not clear to me how I should set-up my map file. I guess, I
>> could on one hand just have 36 layers (for each year a layer) - then
>> I wouldn't need the TIME parameter. But as I have some 1000 files to
>> deal with, my map file would get pretty long...
>> The other solution would be to have some kind of grouping classes, so
>> that all my years would fit into one layer, but into 36 classes.
>> Or is there any kind of more "dynamic" solution?
>> Thanks for any suggestions!
>> Stef
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
