WMS/WFS and (yearly) time-dependent data
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Thu Feb 22 08:27:32 EST 2007
Thanks for the help. Hmmm.... not sure if I do really understand what
you mean. It still feels a bit awkward in my brain....
One point that jumps in my mind is the "mypath/myfile" entry. This
would be if I am working with shapefiles. But I am working with
Postgis. So, how would I have to deal with that one then?
Merci!
Stef
> If your are serving layers as wms you could do soemthing like this :
> - define a tileindex layer example:
> LAYER
> NAME "mylayer"
> STATUS ON
> # TYPE POLYGON
> TYPE RASTER
> METADATA
> "DESCRIPTION" "mylayer"
> "wms_title" "mylayer"
> "wms_timeitem" "time"
> "wms_timeextent" "1970/2006"
> "WMS_SRS" "epsg:4326"
> END
> SIZEUNITS PIXELS
> TILEINDEX "tile_file"
> TILEITEM "location"
> - have a tile index that has at least 2 field (localtion for the
> files, and a time field) :
> location time
> mypath/myfile 2005
> - doing a request of Getmap : something like
> GetMap&Version=1.1.1&LAYERS=mylayer&Time=2005
> Not sure if that fits your model.
> Best Regards
> Bart van den Eijnden (OSGIS) wrote:
>> I think you should be looking at tile-indexing for the TIME
>> dimension. A
>> field in the dbf of the tile-index will probably state which
>> shapefile
>> Mapserver needs to open for that specific year (and that specific
>> theme).
>> I believe the WCS howto has some information on how to do this,
>> but I have
>> no experience with this whatsoever:
>> http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
>> Best regards,
>> Bart
>> OSGIS, Open Source GIS
>> http://www.osgis.nl
>> --------- Oorspronkelijk bericht --------
>> Van: Stefan Schwarzer <stefan.schwarzer at GRID.UNEP.CH>
>> Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
>> Onderwerp: [UMN_MAPSERVER-USERS] WMS/WFS and (yearly) time-
>> dependent data
>> Datum: 21/02/07 09:44
>>> Hi,
>>> i read in a document ( http://mapserver.gis.umn.edu/docs/howto/
>>> wms_time_support/view ) that there is a WMS/WFS-parameter one
>>> can specify for time dependent data. I am dealing mostly with
>>> statistical data sets, which are covering a period of 1970 to
>>> 2006. So it should be something like TIME=2004 to query a
>>> specific year.
>>> For each variable and year there is a five-classes breakup.
>>> It is not clear to me how I should set-up my map file. I guess,
>>> I could on one hand just have 36 layers (for each year a layer)
>>> - then I wouldn't need the TIME parameter. But as I have some
>>> 1000 files to deal with, my map file would get pretty long...
>>> The other solution would be to have some kind of grouping
>>> classes, so that all my years would fit into one layer, but into
>>> 36 classes.
>>> Or is there any kind of more "dynamic" solution?
>>> Thanks for any suggestions!
>>> Stef
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
