Mapserver WMS & ArcGIS : Connnection Problem
Külli Tiits
kylli.tiits at GMAIL.COM
Fri Feb 23 05:56:58 EST 2007
I think you must add the '&' sign after the URL, like:
http://gridca.grid.unep.ch/cgi-bin/mapserv?map=/www/geodataportal/htdocs/mod_map/geo_wms_y_2004.map&
When I tried so, then I got the layers list displayed in ArcMap, but I
still do not see anything on the map..
But may-be it gets you further.
Külli
Stefan Schwarzer wrote:
> Hi,
> i read in a couple of posts that it is possible to connect with ArcGIS
> 9.0 SP 3 to WMS. I can indeed open in ArcCatalog the dialog box and
> enter the URL ( http://gridca.grid.unep.ch/cgi-bin/mapserv?
> map=/www/geodataportal/htdocs/mod_map/geo_wms_y_2004.map ) but then it
> says "Failed to connect to server"... But if I type the address into
> any browser, it does work fine (I mean, error message, ok, because no
> parameter was specified...).
> GetCapabilties:
> htdocs/mod_map/
> geo_wms_y_2004.map&service=wms&version=1.1.1&request=getcapabilities
> GetMap:
> htdocs/mod_map/
> geo_wms_y_2004.map&service=wms&version=1.1.1&request=getmap&layers=gdp_c
> apita,int_boundary_lines,continent_outlines
> Any idea why this could be?
> Thanks for any hints!
