SLD parameter ignored on MapServer Debian (solved!)
Just van den Broecke
just at JUSTOBJECTS.NL
Mon Feb 26 08:18:53 EST 2007
I have solved the issue by tweaking .map en .sld settings. My
installation thus supported SLD (OGR). The SLD filters features from
PostGIS but missed a (Line)Symbolizer element. Now selected features are
drawn, very cool! Next trying SLD_BODY=... best,
--Just
The Netherlands
http://www.justobjects.nl
Just van den Broecke wrote:
> Hi,
> I am trying to use the SLD parameter with MapServer on Linux (Debian
> Etch) but this parameter seems to be ignored (e.g. no messages related
> to SLD with DEBUG ON, even if I pass in a stale URL or onvalid XML).
> I've read several posts on this issue. Mostly the answer was to compile
> with USE_OGR. As I have been using the standard Debian apt-get install I
> am trying to figure out first if OGR is already enabled. mapserv -v shows:
> MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> Looks like OGR is supported (?). My installation is working for standard
> WMS usage, it is only that passing SLD=<sld-url> seems to be ignored.
> thanks,
> --Just
> The Netherlands
