queryByAttributes - speed
Jeppe Lund Andersen
JXA at COWI.DK
Tue Feb 27 06:06:56 EST 2007
Hello all
Iam running php mapscript on a windows 2003 server and when Iam using
queryByAttributes, but it take some time to perform the search.
It takes between 7-8 sek for this linie
$Qry = @$Layer->queryByAttributes($ID_navn, '(' . $Search_Str .')',
$ResultType);
The file iam using is a mapinfo file which has cadastral information.
there are 156612 records in the file and the coln iam searching in has
been index via mapifno.
the field is a text field
Am I doing something wrong ?
Jeppe
here is the funktion that load the map and perform the search
function FindExtendForMatrikel()
global $GISREF_LAYER_NAME, $MAP_PATH_NAME, $MAP_FILE_NAME,
$MATRIKEL_ID_NAME;;
global $xmin, $ymin, $xmax, $ymax;
global $MATRIKEL_LAYER_NAME, $starttid, $kort;
$Shape_matr = array();
$Result = mssql_query ("select * from kort WHERE name = '".
$MATRIKEL_LAYER_NAME . "'");
while ($row = mssql_fetch_array($Result))
$Map = ms_newMapObj($MAP_FILE_NAME);
$Layer = ms_newLayerObj($Map);
$Layer->set('name', "MatrikelSearchLayer");
$Layer->set("connection", $row['MS_CONNECTION']);
$Layer->set("connectiontype", MS_OGR);
$Layer->set('status', MS_OFF);
$Layer->set('type', MS_LAYER_POLYGON);
$Layer->setProjection($row['MS_PROJECTION']);
$Class = ms_newClassObj($Layer);
$Class->set('name', "Matrikler");
$Class->set('template', 'void');
foreach ($kort->objekter as $value)
if ($value->ObjType() == "Matrikel")
$ID_value = $value->id;
$Layer =
$Map->getLayerByName("MatrikelSearchLayer");
//$ID_value = "78065110g";
$ID_navn = $MATRIKEL_ID_NAME;
$ResultType = MS_MULTIPLE;
$Search_Str = "";
$matr_array = split(',', $ID_value);
foreach ($matr_array as $matr)
if ($Search_Str != "") {
$Search_Str .= " OR ";
$Search_Str .= " '[$ID_navn]' = '$matr'
. $Search_Str .')', $ResultType);
$QryRes = $Layer->getNumResults();
if ($QryRes == 0 ) { $kort->matrikelsogning =
NULL;}
for ($I = 0; $I < $QryRes; $I++)
$Res = $Layer->getResult($I);
$Layer->open();
$Shape_matr[] =
$Layer->getShape($Res->tileindex, $Res->shapeindex);
$Layer->close();
