dBox for non-map images
P Kishor
punk.kish at GMAIL.COM
Tue Feb 27 19:01:29 EST 2007
Hi Steve,
I solved it, using an old rubber band script (from the old MapServer
site), and adapting it to make it better. I will release it for the
community in a day or two as a better, simpler alternative. More info
when I release that.
Many thanks,
> On 2/27/07, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> > I assume you're not talking about using the coordinate management in
> > mapserv.js then right? Assuming
> > then that you know what to do with the x1,y1,x2,y2 values you get from
> > dBox then you certainly could
> > use it. A bit more on your overall objective might help though as I'm
> > sure there are other image zooming
> > alternatives.
> > Steve
> > >>> P Kishor <punk.kish at GMAIL.COM> 2/27/2007 10:43:38 AM >>>
> > Greetings,
> > I would like to use dBox (well, basically just the rubber-band zoom
> > box thingy) for a non-MapServer map image. The image is dynamic (I am
> > creating charts using GD::Graph), that I would like to be able to zoom
> > in on. Theoretically I see no reason why dBox couldn't do that, but I
> > wanted to ascertain, before I diving in, that I am going to correct
> > route. Any examples of this would be very welcome as well.
> > Many thanks in advance
> > Puneet Kishor http://punkish.eidesis.org/
> > Nelson Inst. for Env. Studies, UW-Madison http://www.nelson.wisc.edu/
> > Open Source Geospatial Foundation http://www.osgeo.org/education/
> > collaborate, communicate, compete
