WCS from multiple netCDF returning only background image
edfialk
wef1 at CEC.WUSTL.EDU
Tue Feb 27 13:22:41 EST 2007
Hi, I have about 40 netCDF files I'm wishing to serve, each one is a
different year.
Following the netCDF outline at
http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo I am able to
get an image to display, but is only the background color I specify in the
map file.
In the document it states what OGRInfo looks like for the timeIndex shape
file, and mine looks nothing like it.
Should look something like:
OGRFeature(timeIndex):116
location(String) = mytime.tif
time(String) = 2001-01-31T18:00:00
POLYGON ((xxx,xxxx,.......))
Mine looks something like:
[root at niceguy RETRO]# ogrinfo RETRO.shp
INFO: Open of `RETRO.shp'
using driver `ESRI Shapefile' successful.
1: RETRO (Polygon)
This shape was generated using:
gdaltindex RETRO.shp *
Then, I ran the Perl script from the Use Case document (after modifying
based on file structure - no month,day,hour in my file, only year), then I
made the map file.
After a couple of errors, cannot find file, incorrect tileIndex, I got the
GeoTiff returned, but it's just the background image.
Here's the layer parts of my map file, just in case:
LAYER
NAME 'time_idx'
TYPE TILEINDEX
DATA 'RETRO'
FILTERITEM 'time'
FILTER '%time%'
END
LAYER
NAME 'Retro'
STATUS OFF
TYPE RASTER
DUMP TRUE
TILEINDEX 'time_idx'
PROJECTION
"init=epsg:4326"
END
METADATA
wcs_label 'Temperature data'
ows_extent '-180 -90 180 90'
wcs_resolution '1.125 -1.125'
wcs_size '2700 3197'
ows_srs 'EPSG:4326'
wcs_formats 'GEOTIFF_FLOAT'
wcs_nativeformat 'netCDF'
wcs_bandcount '27'
wcs_rangeset_axes 'bands'
wcs_rangeset_label 'Level units'
wcs_rangeset_name 'bands'
wcs_rangeset_description 'Z levels '
wcs_timeposition '1960-01-01T00:00:00,2000-01-01T00:00:00'
wcs_timeitem 'time'
END
END
END
and here's the getcoverage request URL:
http://niceguy.wustl.edu/cgi-bin/mapserv?map=/var/www/html/mapserver/RETRO.map&version=1.0.0&service=WCS&CRS=EPSG:4326&request=GetCoverage&COVERAGE=Retro&WIDTH=800&HEIGHT=600&FORMAT=GEOTIFF_FLOAT&TIME=1960-01-01T00:00:00
If anyone has any advice or thoughts about why it's just a blank color
image, I would be greatly appreciative.
Also, anyone happen to know the OutputFormat syntax for netCDF?
Thanks in advance!
-Ed
View this message in context: http://www.nabble.com/WCS-from-multiple-netCDF-returning-only-background-image-tf3303314.html#a9188566
Sent from the Mapserver - User mailing list archive at Nabble.com.
