projection offset
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Tue Jan 9 08:15:57 EST 2007
Steven,
have you updated your PROJ.4 parameters? PROJ 4.5 should contain the right
ones.
This should be it, check your epsg file:
<28992> +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +units=m
+towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
+no_defs <>
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Steven M. Ottens <steven.ottens at GEODAN.NL>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: [UMN_MAPSERVER-USERS] projection offset
Datum: 09/01/07 11:05
> Hi all,
> I've got a problem with reprojecting data (shapefiles) with mapserver:
> I've got data in shapefiles as wgs84 (epsg:4326) I need to be able to
> reproject them in various coordinatesystems. However if I request the
> data as dutch RD (epsg:28992) and overlay it with a shapefile with
> the same data in epsg:28992 I get a vertical offset. (see attached
> image; the red and black line should overlap.)
> If I reproject the data as UTM 30 I get a horizontal offset. Is there
> a magic trick to get mapserver reprojecting data on the fly? I've
> attached my mapfile if that helps.
> regards,
> Steven
