Tileinidex cannot be used for CGI controls
Frank Warmerdam
warmerdam at POBOX.COM
Wed Jan 10 11:47:27 EST 2007
Marc Jacquin wrote:
> Thanks Steve and best wishes to everyone for 2007.
> Frank, it seems that you included this update (TILEINDEX in
> loadLayerString) in FWTools 1.1.3 version dated January 5^th 2007. Can
> you confirm ?
Marc,
The mapserver source for FWTools 1.1.3 would have been pulled from CVS
on January 4th or 5th. I see Steve made a change in mapfile.c related
to tileindex/cgi handling on December 29th, so this is definately in
FWTools 1.1.3. I'm not sure if this is the only change you are speaking
of.
> On another hand, it seems that for some FWTools versions (1.1.3 at
> least) JPEG rendering does not work -zero size image- (JPEG only,
> PNG/GIF is OK), with no error message in debug.
I just tried "shp2img -m rot_out.map -o out.jpg" on msautotest/gdal/rot_out.map
after changing the IMAGETYPE value to jpeg, and it produced a valid jpeg
file. So I don't think jpeg output is generally broken. Perhaps there is
some issue with your map, or your configuration?
> Finally has FWTools 1.1.3 been validated on W2003 server R2? I could not
> get my own Mapserver version running on W2003 server (compiled with VS
> 2005 and FWTools libs).
Folks have run FWTools on Win2003 (I don't know the revision) though I don't
know whether the mapserver was used there.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
