Implementing combo boxes {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri Jan 12 11:49:04 EST 2007
Hi Willem,
You can use the select item in a html form. You will get the selected
value in the query string like
controlname=value
If you would like to serve few number of shape files, then you can create
a map file all layers involved and turn on/off layers through the query
string.
I usually do it using checkboxes or multiselect lisboxes.
If you would get more freedom you should use mapscript.
Zoltan
On Fri, 12 Jan 2007, Willem Coetzer wrote:
> Does anyone have experiencing implementing combo boxes in Mapserver. I want
> the combo boxes to list shapefiles that the user can add to the display and
> legend. I just need a broad approach or any tips.
> Thanks
> Willem
