[Fwd: RE: [UMN_MAPSERVER-USERS] broken query]
John B. Churchill
jchurchill at AL.UMCES.EDU
Fri Jan 12 11:48:25 EST 2007
I am doing a spatial query of a polygon layer. The query that I have
working is a line layer but I don't think it has anything to do with that.
my Layer is defined thusly ...
LAYER
NAME landsat_4
TYPE POLYGON
DATA landsat_4
STATUS ON
CLASSITEM LOCATION
CLASS
NAME "Landsat Data"
STYLE
COLOR 40 40 200
END
STYLE
OUTLINECOLOR 0 0 0
WIDTH 1
ANTIALIAS TRUE
END
END
TEMPLATE "templates/landsat_4.html"
END
and the template (templates/landsat_4.html) looks like this ...
<table border="2" cellspacing="2" cellpadding="2">
<tr><td>File Name</td><td>Imagery
Source</td><td>Path</td><td>Row</td><td>Projection</td><td>Datum</td><td>Image
Date</td></tr>
<tr><td>[LOCATION]</td><td>[SOURCE]</td><td>[PATH]</td><td>[ROW]</td><td>[PROJ]</td><td>[DATUM]</td><td>[IMGDATE]</td></table>
All the fields occur in the layer "landsat_4.shp" just as they appear in
the html template.
Are you doing a point query or an attribute query?
Posting relevant test from you map file and template would help people
diagnose the issue.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of John B. Churchill
Sent: Friday, January 12, 2007 9:19 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] broken query
I'm still working on modifying the basic ITASCA DEMO. I got some
queries to work in one application (returns data from the dbf table) but
they aren't working correctly in another (returns a table that looks
like the static template file without any data).
In both I have followed these steps:
1. Created Templates in the "templates" folder named after the layer
and with the appropriate fields in square brackets [].
2. put a statement in the MAP file at the end of the layer block that
refer to the html file in step 1 like so ...
TEMPLATE "templates/anti_bnd.html"
Are there other steps that I need to follow. If so I must have done
them in the first case but forgot about them in the 2nd case. Any help
on this is appreciated.
J.B.
John B. Churchill, M.S.
http://alx.al.umces.edu/~jchurch/
GIS Specialist (301) 689-7109
University of Maryland Center for Environmental Science
Appalachian Laboratory http://www.al.umces.edu/
Environmental Science Education http://alese.al.umces.edu/
301 Braddock Road
Frostburg, MD 21532
FAX - (301) 689-7200
John B. Churchill, M.S. http://alx.al.umces.edu/~jchurch/
301 Braddock Road
Frostburg, MD 21532
